any one wiilling to give a newbie starting advice
As my previous posts says I just got my TPI in and running
I am using craig's software
any how I took my car for a quick rip around the neighborhood logging data
is there any one willing to look at the data and bin to give me a good idea of where I should start modifying?
or if this isnt some thing people normally do point me to some where that will be a good resource
now another question
every time I turn off my car the rad boils over unless i let it idle for a min or so
is there a way to make the computer keep the fan on for a bit after turning the key off?
or should I just lower the on temp for the fan to turn on ( which is set to on=107.8C off=104.8C) it has a 190 thermostat
hope i am not asking retarded questions this is a brand mew world for me. not getting my hands dirty
Car: 87 IROC-Z
Engine: 383 HSR $8D
I'd start by reading Traxion's tech article...there are several good links there to tuning info...kinda read those and piece together where to start. FIRST thing I did when I got my burner was to turn my fan on temps down...then I tweaked the simple things...like idle speed, etc. THEN started on fuelling tables...I haven't even started looking at spark yet...but I don't have much time to futz with it. There are several good posts on this board on where/how to start and I have printed off many. If you have a question on something...do a search for it on here and read the posts...you may have to search a few different ways to find the answers you want.
Other than that...the general mood I have found among prom burner pros is 'dive in and figure it out yourself and you'll learn more'...
GregF
87 IROC
GregF
87 IROC
theshackle
Mar 5, 2017 06:37 PM
