Think I'm ready to burn
I've been running DataMaster on my truck (16147060 ECM) for the last few days and found that my BLM averages around 113. This makes sense because I put a bit hotter cam in and, if I understand right, that will cause me to run rich. My short term counts are usually below 128, but at some RPM/KPa combinations I run a bit lean around 130 to 132.
So, am I right to think that I can change my Base Pulse Width Constant to make it run leaner? Then work on my VE vs. RPM vs. Load table to address any lean areas?
Which way should I go with the BPW constant to runn leaner and which way do I go with the VE table to run richer?
Thanks!
Thanks!
Sounds like you have the right idea. Get the VE tables roughed in a little more like you've said and then work on some spark tables then go back to the VE tables(spark tables alterations will affect the VE tables).
Depending on how far off your numbers are is if you should just change the VE tables themselves or change the injector pulse width then go to the VE tables directly.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Brendan
Glowsock
Sep 11, 2015 11:09 PM
