PE vs RPM Thresholds
Old Sep 20, 2001 | 07:50 AM
89vette's Avatar
Stock values for PE vs RPM normal temp in the 90Vette bin are 70%. What guidelines are used for tweaking these? What I mean is it just where I like them? Does enabling PE at say 40% have any adverse effect? I have them set to 90% currently for upper RPM VE tweaking and the car feel just as powerful.
Jason
Old Sep 20, 2001 | 09:47 PM
drive it's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 89vette:
Jason
</font>
I'm not sure of any adverse effects from lowing PE(other than poor fuel mileage), but if you raise it too much I can see where it would run too lean/hot(in the cylinder) and could potentially cause a meltdown. As Grumpy always says-read the plugs-that should tell you if you went to far. Personally I'm leaving it at 70% as I've still got a lot of other areas to dial in yet.
86 406
[This message has been edited by drive it (edited September 20, 2001).]
Old Sep 21, 2001 | 12:18 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Having a high TPS threshold for engagin PE is fine for "tuning" the VE tables to avoid it giving you "weird" results.
But once, you are close, I prefer a lower TPS setting. I find that when the PE kicks in, it feels like the secondaries opening up on a 4 BBL carb.
Old Sep 21, 2001 | 08:15 AM
89vette's Avatar
I set my table last night to the following values:
400 60%
1200 50%
2000 45%
3200 45%
4800 45%
This seemed to make a huge difference. I gave my buddy a ride last night that has not ridden in the car since I built the 396. I started out in first and at about 15MPH or so I nailed it and almost lost control. The rear end was fishtailing all around. The power is just wicked. A quick shift into second and she still just lights the big 285's up. I'm sure I have way too much torque with the SR setup than I can use but its sure alot of fun!
Jason
Old Sep 21, 2001 | 09:17 AM
Car: Death Mobile
Engine: 666 c.i.
That is very close to what I run. Once you get the VE Tables very close (which I know you have), you can actually feel it when you give it just over 1/2 throttle. As I said before, it feels like the secondaries kicking in on a 4 BBL carb.
I wouldn't go too much lower though or you end up wasting gas and it could effect your emissions testing.
ULTM8Z
Oct 2, 2015 01:25 PM
Giocio
Oct 1, 2015 12:20 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
