Has anyone used Carchat scanning software?
Old Sep 22, 2001 | 06:08 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I need the files to make carchat work for a 7747 ecm. If anyone has them please e-mail me.
'92 Astro 350 TBI Edelbrock intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Sep 22, 2001 | 06:50 PM
Brent's Avatar
Version 2.2 does not work with the 7747 160baud aldl despite the instruction's implication that it does.
Version 3.02 has sample 160baud files. It does require a PIC based hardware interface to work with 160baud.
3.02 is availible at ftp.diy_efi.org/incoming/
Old Sep 23, 2001 | 03:48 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Ok cool. I checked my versions and I have 3.02. The thing is that its only setup to work with the AUJP or whatever.
It looks like there are provisions for programming your own "gauges" and that, but I know nothing about programming. I was actually grovelling and hoping someone had already made them, so they could pass it on to me.
The program looks much more able than the one I have, and would be great if I could get it to work.
Old Sep 23, 2001 | 05:33 PM
Brent's Avatar
I think if you look a little closer you will find that the 160baud files are provided.
No programming is required. You right click on a gauge to change it or right click on the blank area to add a gauge. Check out the Help section on the tool bar for all the specifics.
Old Sep 24, 2001 | 12:05 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Thanks Brent, your the only fella here that helps me out with this stuff. I really have no idea what I'm doing, but I would like to!
I took a look at that and I see that the 160 Baud stuff comes with it. But I don't know about all that byte and formulas stuff. I played with it for hours and didn't get anywhere. I can't seem to find any info on which bits/bytes go to what.
[This message has been edited by V8Astro Captain (edited September 23, 2001).]
Old Sep 24, 2001 | 11:12 AM
fast_broker's Avatar
Does CARCHAT allow you to "data-dump" tons of BLM vs MAP vs RPM data (for example), like Diacom and Craig Moates???????
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
Deemax
Sep 12, 2015 06:53 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
