870-165-gear ratio
Old Sep 22, 2001 | 05:56 PM
tpi_roc's Avatar
870-165-gear ratio
OK guys,
Got sick of the 870 So im putting in the 165. But I have a problem now and im wondering if its going to compound with the new ecm/memcal. My car had 3.42's origanally and now is running 3.73's, I've noticed since looking into prom burning that you can burn in your AXLE ratio and I know that it isnt' for your speedometer, so what is it for? and how can the difference in axle ratio without the prom knowing about it negativly effect my drivability? Basically I have a spark knock at higher rpms and im wondering if its because of the 3.73's, thanks!
Old Sep 24, 2001 | 12:30 AM
v8power's Avatar
WHere do you change the ratio? I am going to be changing my gears soon and I have not seen where to set the ratio
I am using the ARAP.bin $6e
1986 IROC 350 5spd
just installed a TPI from a 1988 IROC, 24# lt1 injectors,165 ECM MAF, custom sub frame
Old Sep 25, 2001 | 09:56 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am interested as well. is it a SD only program? or do the maf have it too?
Old Sep 26, 2001 | 03:20 PM
tpi_roc's Avatar
Appears i was wrong, the difference is the timing curve. Numerically higher gears = less load/more timing. etc.
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
