Scanner Hardware...please read...
Old Sep 24, 2001 | 10:20 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Can anyone link to or e-mail me the electrical schematic for the ALDL/serial interface they used.
I have found about 6 or 7 diagrams, all different. I have no idea which one will work and which one won't. I know what they are *supposed* to do and which baud rates they are at, but I just want to be sure I don't nuke my ECM (or my brothers laptop) when I hook it up.
Most involve the use of the MAX232A chip which is coming in the mail. But some of the diagrams get power from the ALDL and some from the DB9 serial port (?). I didn't think that the circuit could get enuf power from the DB9 to run.
TIA
'92 Astro 350 TBI Edelbrock intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Sep 26, 2001 | 11:47 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by V8Astro Captain:
TIA
</font>
Why spend the money on a cable?.
You could buy a gal or two of gas?.
(In like reply, to your WB O2 posting)
Old Sep 26, 2001 | 04:36 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
<font face="Verdana, Arial" size="2">Originally posted by Grumpy:
</font>
Well, LIKE, at least I got LIKE, a response from someone. Seems to me that most of you don't know anything, OR just don't like to help anyone outside of your little circle of programming friends.
In regards to the O2 sensor thing, it was an attempt at humor I guess you didn't grab, or didn't agree with SORRY!
I'm sure some of you know a millions times more about this than me, it just sux that when I need help nobody responds, which is ok if I ask a rediculous question.
What I asked for was far from rediculous because I know some of have made an interface cable and the plan probably didn't fall from the sky.
Old Sep 26, 2001 | 06:32 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Don't be a dork. There are a variety of schematics and most work. Pick one which matches your skill level and build it. Then try another one for fun. Then design your own...
Try one which uses +12v supply from the cigarette lighter, then you won't drain your com port and you won't have any voltage to/from the ECM... Max 232 or 233 have both worked for many...
[This message has been edited by Craig Moates (edited September 26, 2001).]
Old Sep 30, 2001 | 02:17 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by Craig Moates:
</font>
All of them can be powered from the cigarette lighter outlet, just use a 7805 voltage regulator to get 5 volts.... And don't forget to put a fuse inline in case you should short something out!
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Old Sep 30, 2001 | 08:27 PM
davidjon_99's Avatar
I bought a completed cable from here http://www.mindspring.com/~amattei/aldl.htm
Andrew does a great job and sent it to me very quickly.
He has free schematics on his site. He has kits and assembled cables you can buy.
whtltng89
Sep 8, 2015 07:06 PM
Electro_X
Aug 19, 2015 07:59 AM
mizz0313
Aug 12, 2015 06:45 AM
bowtie1983ss
Dec 4, 2001 12:18 AM
Mark305TBI
Jan 28, 2001 11:20 PM
