AT Sensor and Closed Loop
Old Oct 2, 2001 | 12:14 PM
z28dan's Avatar
On a stock bin, what air temp does the AT sensor need to read to go into closed loop? Can this be changed in Tunercat? I am running 6E code. Today on the way to work the engine would not get off high idle, coolant temp was normal, outside air temp was in the 50s here. So I am guessing that in the AT sensor was reading about 70-80ish. I don't have egr and did a TB bypass, so on a 70 degree day my AT reads 90s. Any ideas?
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Oct 2, 2001 | 01:16 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The air temp sensor has no bearing on when it goes into closed loop, but the coolant temp does (usually 100-122 degrees F in TPI applications). Sometimes, it takes a few seconds, or even up to several seconds, for the computer to close the IAC motor to allow the idle speed to drop down to normal.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 2, 2001 | 01:23 PM
z28dan's Avatar
Darn!!! that's what I was afraid of! My coolant was in normal ranges, the motor high idled all the way to work, over 40 min if driving. The car ran fine last night??? I burned a prom yeasterday afternoon to add a little fuel. Maybe that freaked something out.
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Oct 2, 2001 | 01:31 PM
z28dan's Avatar
I just had another thought, maybe my return spring has gone south. This happen to my friend and it took forever to figure out because it was so simple...
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
FormulasOnly
Sep 10, 2015 09:07 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
