I didn' think this was possible...
Old Oct 15, 2001 | 05:22 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I read in the DIY archives that any open-element air filter bigger than 1" was too big. Huh, mine is 2.5", so I set out to try the remedy. It was said that you can compensate by making the Pumpshots bigger. So I did and the cavitataing noise is gone, and the lag is gone too. Now my BLM is at 117-120 range mainly at 2000 RPM from 30-60 KPa. BUT, the INT is fine!?!? When I get on it real hard, the BLM goes down to 117, the INT is at 126. Then after a while the BLM starts to come back up again to around 120-123. I have read and understand the (INT-128)*.23 articles. I thought the INT "moved" the BLM. On average, low INT will pull the BLM down, so I thought.
What to do?
'92 Astro, GM crate 350, Performer TBI intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
[This message has been edited by V8Astro Captain (edited October 15, 2001).]
Old Oct 16, 2001 | 04:39 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
anybody??
[This message has been edited by V8Astro Captain (edited October 16, 2001).]
Old Oct 17, 2001 | 12:58 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
ttt
Old Oct 17, 2001 | 04:57 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
ttt
Old Oct 18, 2001 | 07:00 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I doubt that any air filter bigger than 1" is too big. Concerning the INT/BLM relationship, in the TPI bins, it takes an INT of +/-5 away from 128 to make the BLM change. So, if your INT is between 123 and 133, the BLM won't change. It didn't change when you got on the gas because you were in Power Enrichment (aka: WOT, but can happen as low at 50% throttle) and the BLM is not updated in P.E.
Greg Westphal
'87 IROC 355TPI/A4
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Thaney9
Oct 24, 2015 07:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
AUZ28
Oct 3, 2015 06:28 PM
