Latest Moates ver., knock retard?
Old Oct 26, 2001 | 07:25 AM
Steve10's Avatar
Has anybody else noticed a difference is the knock retard reporting. It reads tenths (.1) now for one, but normally when I get a count I see quite a few degrees retard (7-9). Now I get a string of .7-2.2 before it goes back to 0. I could actually hear the knock on the 2-3 shift about the time I saw the count on the scan. In the past, when audible knock was present I've seen much more retard. This was my first chip, and with the ARAP I expected to see some knock, but normally I wouldn't be overly concerned with 1-2 degrees. Anybody else?
'87 Formula WS6 - ZZ4 Crate TPI, Scroggin-Dickey ported heads, LT4 hot cam, 1.6RR, Accel runners, Accel base, ported plenum, Edelbrock 58mm TB, Crane Fireball ignition, SLP cold air, SLP 1 5/8 headers, !cat, Summit exhaust cutout, Walbro 255, Koni yellows, Hotchkis panhard & LCA's, 9 bolt w/3.27's.
Old Oct 26, 2001 | 09:13 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I introduced a divisor of 10 to the reported retard values. Is this correct? Folks had suggested it was. Perhaps someone could verify/clarify on this. The numbers I was reporting previously were believed to be exaggerated.
Old Oct 27, 2001 | 11:19 AM
Steve10's Avatar
I wonder if audible knock is an indication that you should be seeing maximum retard, depending on what's in your chip's table. Maybe others can share what retard values they see when using the ARAP tables. Anyhow, knock is knock, so I'm going to be tuning and burning today with a goal of no knock.
Old Oct 28, 2001 | 09:24 PM
86Red4+3's Avatar
Craig,
I was looking at this reference:
http://www.geocities.com/MotorCity/S.../prog_101.html
According to Bruce, the correct divisor is:
Knock retard N x (45/256) 0-45 degrees
or, about 5.7 rather than 10
HTH
Jim
Red '86 4+3
Old Oct 28, 2001 | 11:57 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by Steve10:
</font>
I don't think that audible knock means that you should be seeing max retard. It may happen that way because of loud exhaust and what not drowning out the knock, but really any knock incidences could be audible so you may or may not be at max retard when you hear it.
I ran the ARAP timing tables unchanged in my GTA which is ~10:1 with aluminum heads and I rarely heard any knock. When the spark tables were still untouched, I would hear some knock while on 92 octane at part throttle + heavy load conditions and I would record retard as well. When I would run 100 octane (unleaded), I saw no knock incidences at all. At WOT and heavier loads I never recorded any knock counts with the latest version of Craigs software with 92 or 100 octane with the ARAP spark settings at heavier loads and WOT untouched(I have backed off some of the light load/low rpm timing since that is where I was getting most of the knock when it did occurr).
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
383backinblack
Sep 25, 2015 11:31 AM
ericjon262
Sep 11, 2015 06:07 PM
