Help first burn
Old Oct 31, 2001 | 12:10 PM
righton's Avatar
Help first burn
I need help with my first burn. I have a stock chip which is too rich when started and will not link to diacom . I have a fast prom chip is just ok ,but values are encripted and make no sence.I need some values close to get started , where do I go now??The motor is highly modified
Old Oct 31, 2001 | 07:49 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by righton:
I need help with my first burn. I have a stock chip which is too rich when started and will not link to diacom . I have a fast prom chip is just ok ,but values are encripted and make no sence.I need some values close to get started , where do I go now??The motor is highly modified</font>
What? I understand that you want some help with getting a start on your bin but that is about it. What PROM are you running right now (you say something about a stock one and than a 'fast chip'??)? What hardware and software do you have/are you running (ie scantool, EPROM burner, EPROM type, etc..)? What exactly do you mean by:
<font face="Verdana, Arial" size="2">I have a fast prom chip is just ok ,but values are encripted and make no sence.</font>
What system is it (MAF or SD)? What exactly has been modified on the car?
You really need to make a clear and quality post with your questions if you want the same things in the response.....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 31, 2001 | 08:26 PM
righton's Avatar
Proms that I have are Fomots's TPIS and the stock proms.My testing Equipment is diacom-p and Autio X ray scaner. I have tuner CATS software and the eraser device. The car is mass air controlled The motor is a 406 cid, 1000 cfm throttle body, min ram intake, cam is 250 and 260 @ .050.All the usual stuff nothing stock left on the cat except the paint.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Logan Bryant
Sep 23, 2015 06:51 AM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
