Winaldl Cable
Old Dec 3, 2001 | 05:31 PM
BillD91RS's Avatar
Winaldl Cable
I want to make the cable to interface with the winaldl cable. I can't find the transistor that they have listed on the schematics but it says or similar. What would be an usabe replacement? I will probably go to radio shack for the parts. If you know of a couple that might work will you list them here? Thanks. I can't wait to try that software
Old Dec 3, 2001 | 06:43 PM
Ragin'87's Avatar
this is burried in one of the other posts, Radio Shack Cat. # 276-1617
it's an assortment of 15 of the transistors, but it's $2.49, so unless you want to order it and wait for ONE transistor... it's what I got.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 84k miles.
Old Dec 4, 2001 | 08:18 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Use the MSP2222 (or MPS2222 forgot what the first three numbers are) That Radio Shack carries. Also if the plains you’re using call for diode use the 1N914 at Radio Shack.
Now I HAVE_A_Z
89 IROC 350 TPI
Old Dec 5, 2001 | 02:42 PM
BillD91RS's Avatar
Thank you both. Now to go and get that cable built.
Old Dec 5, 2001 | 02:50 PM
Ragin'87's Avatar
no problem
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
