Built a two trans circuit, need some help getting it going...
Old Dec 4, 2001 | 09:41 PM
86IROC305's Avatar
I got everything hooked up, drug my pc out to my car and hooked up the aldl cable I made. I ran Craig's Software in Dos and can't get it to connect. I get the flickering 00/FC values, but it won't link.
Does the ECM need to be in closed loop for it to connect? I left it up for about 15min and no luck.... any suggestions? Thanks Joe
86 TPI 305 Iroc-Z
WC 5spd
9 Bolt Rear Disc Swap w/ 3.45's
Accel HEI SuperCoil
MSD 6AL
NOS 5151
Comp Cams 260H-12
212/212 444/444 @112lsa
Old Dec 4, 2001 | 09:48 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I build that cable too and i am having the same problem as you. I can not get it ot connect. I pacd the 10K ohm resistor between A B and nothing. All I get is just that lickering as you do.
Can anybody help us out?
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers, 3 inch over the axle, Flowmaster 80, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, AFPR, Smog/AC/Cat Delete, 3300lbs, All free mods
Old Dec 5, 2001 | 12:08 AM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
someone give me the schematic your using and the values of your transistors. drrizt2k1@attbi.com
1987 IROC-Z T-Tops wait... GUTTED MAF!
Old Dec 5, 2001 | 06:36 PM
86IROC305's Avatar
Here's a link to the interface cable I made :
www.andywhittaker.com/ecu/aldl_hardware.htm I'm using the 2n2222a transistor and 1n4148 diode with the three 10k resistors and 1 10k jumping the "A" and "B" terminals exactly the same in the diagram.
86 TPI 305 Iroc-Z
WC 5spd
Accel HEI SuperCoil
MSD 6AL
NOS 5151
Comp Cams 260H-12
[This message has been edited by 86IROC305 (edited December 05, 2001).]
colton_carlson
Mar 8, 2019 12:21 PM
stalkier
Aug 21, 2015 01:54 AM
jharrison5
Aug 19, 2015 05:53 PM
