8D Open Loop Question
I've got my car tuned pretty good. In fact when in closed loop and warm, I got it to idle pretty good. When it's cold, I believe it needs more fuel. In the "Loop Open % Change AFR Vs. Temp.", do I need to increase those values cold to get it run richer or decrease it?
Thanks.
Thanks.
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
higher numbers are more fuel. You can do the calculations...
7% = .07
11%=.11 (etc.)
14.7 x 1.07 = 15.7 This is the estimated AFR for a 7% change (7 in the table)
14.7 x 1.11 = 16.3 and so on...
7% = .07
11%=.11 (etc.)
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
Hi!!
just a question...
an AFR of 14.7 means, 14.7kg of Air are mixed with 1 kg fuel...thats stoich..
when you calculate like above, that means, eg. 15.7kg of Air for 1 kg fuel..so its going to be lean...
so, larger numbers means less fuel, or im completely wrong now?
regards
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Calc is in reverse. Should not be adding to the air side of the equation.
Positive values will add fuel by REDUCING the AFR.
Long night there AtomicTruck ?
Transmission: TH350
my BAD!!!
7% would be 1 - .07 = .93 Which would be .93 x 14.7 = 13.7 AFR
Besides the brain fart... the larger the number in the table the richer the mix.
Sorry
Sorry
Transmission: TH350
Wierd.
I just started an edit on my post but decided to just leave and clicked the back button. Then it looked like my post wasn't there. So I started to retype it but looked below the post window and it was there. Hmmm.
Thanks JP86SS. Yes, sometimes I stay up too late. I can read a few, post a few and when I look at the clock it is 1 am before I know it.
