85 tpi proms
Old Dec 13, 2001 | 01:52 PM
kabar14342's Avatar
85 tpi proms
i was reading the into to prom burning article and wanted to know if the same things apply to the 85 tpi setup, i currently took out the 85 305tpi, dropped in a 85 350 4 bolt block, put on a tpi system with a ported base, and 22lb injectors, and im now trying to learn how to burn a custom chip for my 305ECM that im running so i can get the performance i need,
matt 85 z28
Old Dec 13, 2001 | 02:31 PM
drive it's Avatar
Yup, same tuning principles apply, although I think you'll find it worth it to swap to the later 165 (maf) or speed density. You'll have a lot more "tuning ability". eg- look at the maf tables from the 1F to the 6E code to name just one.
86 406
Old Dec 13, 2001 | 02:35 PM
kabar14342's Avatar
i have a 88 350 ECM, that i could use will it work with the 85 wiring harness, and then i can tune it to specs
matt
Old Dec 13, 2001 | 03:06 PM
drive it's Avatar
<font face="Verdana, Arial" size="2">Originally posted by kabar14342:
matt
</font>
check out www.eecis.udel.edu/~davis/z28/ He did the swap from 85 to the 165 ecm (86-89 ecm) and the to speed density and did a great job of writing up the needed wiring changes.
86 406
Old Dec 13, 2001 | 03:26 PM
kabar14342's Avatar
thanks, alot, any further info will be helpfull as well thanks guys
Old Dec 13, 2001 | 04:26 PM
tpi_roc's Avatar
I also have an ecm
I followed mike davis's technical article to a T with not a single hitch.
I'm now running on a 165 and going to swap to a '730
1985 Iroc-z, 14 second 305, new engine in the works.
Steven 86IROC-Z
May 24, 2026 04:52 AM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
