Two-Transistor Interface
Old Dec 13, 2001 | 04:53 PM
Clutch's Avatar
I've been looking around at schematics for different ALDL interface cables and found several different variations. Could someone with the 7165 let me know the cable that they are "really" using, some of the schematics say that you should run another 10k resistor in series with the base on the upper transistor, some say this is for a lotus aldl, some say you need to put a 10k resistor between the a+b terminals... I could try all of these, but I'm afraid I'd mess something up, so if someone has a working two-transistor config that they use on a 7165 I'd really like to hear from ya.
Thanks!
Old Dec 14, 2001 | 12:23 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Ok...this is what I've read:
*If you use the two transistor interface you have to put a 10k resistor on the upper transistor.
*To initiate communications to the ECM (ALDL mode) you need to set a 10k between the A-B pins.( if you short A-B you get diag.mode and if you get 3,9 k you get factory test mode)
I would'nt run the two transistor deal if it isnt a 160 baud ecm, go for the MAX 232 interface instead.
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods soon superram and DFI http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
[This message has been edited by gta324 (edited December 13, 2001).]
Old Dec 23, 2001 | 09:04 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well i just got the cable to work today with Craig Moates software. The schematic I used came from this websight http://www.andywhittaker.com/ecu/aldl_hardware.htm I also used a 10k resistor between the A and B pins and got the 12V from the cigarette lighter.
Old Nov 10, 2002 | 04:09 PM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
I have got the 2 transistor interface to link perfectly. It works fine with Craig's software although I don't know which version of the software I am currently using.
Old Nov 13, 2002 | 07:24 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Is it possible to use the two transistor cable with Craig moates software on a 8192 baud ECM?
Old Nov 13, 2002 | 11:40 AM
Car: 1991 T-Top RS
Engine: 305 TBI
Yes it definatly is. fully compatible with the software
Old Nov 23, 2002 | 10:01 AM
primo's Avatar
Do yoy know a sourse for the ALDL Molded connector to connect to the ECM?
Thanks,
350tbi
Apr 15, 2002 11:31 AM
jnjspdshop
Apr 12, 2002 11:03 PM
Christos
Nov 16, 2001 06:47 PM
