EBL: Digital Dash - 84 Vette
Old Nov 4, 2006 | 05:34 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
Is the MPG display supposed to work with the EBL?
Old Nov 5, 2006 | 07:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, the EBL ALDL stream can be the normal diag stream or the Digi-Dash stream. Need to set OptionWOrd3 bit 7: "DglDh - Enable Digital Dash ALDL stream" to enable the digi-dash stream. This bit is set with the provided EBL BIN.
If the ECM is in a diagnostic mode via 10K or shorted AB the Digi-Dash steam will revert back to the standard ALDL diag stream.
RBob.
Old Nov 6, 2006 | 08:52 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Jim,
You'll need to play with the factor in order to get it close to actual MPG. It gets a bit more complicated when using the VAFPR.
Old Sep 11, 2007 | 01:14 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Re: EBL: Digital Dash - 84 Vette
whats the ebl
Old Sep 11, 2007 | 10:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by Calderone
whats the ebl
It is short for the EmBedded Lockers system. Which is a package of hardware, firmware & software for TBI & port injected engines. It uses the '86 through '95 MY series of TBI ECMs with a board added in. This board provides for high speed data logging, along with additional inputs such as WB's and pressure transducers.
A Windows program is provided for logging, display, and analysis. The ECM code (BIN file) is provided that has additional functionality and better code (the engine runs better).
The EBL Flash system does away with chip buring. There is Flash memory on board that contains the calibration data. This is updated via the Windows program via the same cable (provided) that is used to data log. It is an integrated package for engine management & tuning.
RBob.
Vintageracer
Sep 24, 2017 12:34 PM
Lbibb
May 5, 2016 12:00 AM
86IROC112
Nov 7, 2015 06:50 AM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
