Datalogging 165 ECM incomplete data??
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
I'm using the external 12v source cable from http://winaldl.joby.se/aldlcable.htm and i'm using WinALDL and it's not showing me all of the data that it should...i'm not getting any O2 readings or spark readings...the only things it does show me are the RAW data, and the SENSOR data, and the Dash works What do you think is happing there??
And in the Dashboard thing in the program, it shows my rpms okay but it says that my TPS is .2v but when I check it with my DMM under the hood right at the sensor it is telling me .54 volts?? That can't be good can it??
And I have to use the 10k to get it to transmit data, but after awhile in this mode idling, it starts to plub plub plub making weird exhaust sounds and hesitating?? What would be going on there???
Maybe it's just WINALDL...what other software would I be able to use with this same cable, and using pins A and E?? I don't have pin M....does that mean no 8162 baud data??
Thanks! -Tyler
Thanks! -Tyler
