a/d temp chart
Old Dec 12, 2006 | 05:34 AM
escort_ford84's Avatar
a/d temp chart
My temperature thresholds are in a/d and a/d counts. "CldLp - Closed loop coolant threshold" has this in the item discription "Use a/d temp table to find desired temp." is there a chart that i can look this up?
Old Dec 12, 2006 | 07:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Look for table 1 in the 8746 hac. It follows the ALDL data stream table.
RBob.
Old Dec 12, 2006 | 09:18 AM
Ok i found it. thanks
Old May 17, 2011 | 08:53 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: a/d temp chart
Rbob, just another question for you about A/D counts to DEGREES CELCIUS SCALING. I have 2 files here in Efi live . The corvette L98 and the camaro L98 file. The scales look the opposite ,take a look, First one is Vette: A/D TO DEGREES CELCIUS SCALING
; "RAWADMAT"
; A/D COUNTS DEGREES 'C'
; 0 -40
; 4 -30
; 5 -25
; 8 -20
; 10 -15
; 14 -10
; 18 -5
; 24 0
; 30 5
; 37 10
; 46 15
; 56 20
; 66 25
; 78 30
; 90 35
; 103 40
; 116 45
; 129 50
; 141 55
; 153 60
; 163 65
; 174 70
; 183 75
; 191 80
; 199 85
; 205 90
; 211 95
; 216 100
; 221 105
; 225 110
; 229 115
; 232 120
; 234 125
; 237 130
; 239 135
; 241 140
; 242 145
; 243 150
; 255 200
now here is the Camaro one: A/D COUNTS DEGREES 'C'
; 255 - 40
; 251 - 30
; 250 - 25
; 247 - 20
; 245 - 15
; 241 - 10
; 237 - 5
; 231 0
; 225 5
; 218 10
; 209 15
; 199 20
; 189 25
; 177 30
; 165 35
; 152 40
; 139 45
; 126 50
; 114 55
; 102 60
; 92 65
; 81 70
; 72 75
; 64 80
; 56 85
; 50 90
; 44 95
; 39 100
; 34 105
; 30 110
; 26 115
; 23 120
; 21 125
; 18 130
; 16 135
; 14 140
; 13 145
; 12 150
; 0 200
Does this make any difference?
Old May 18, 2011 | 06:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: a/d temp chart
If this is for the CTS value from the ALDL stream they are both wrong.
CTS in *C = (val * .75) - 40
The Vette (first one) chart is correct for the ALDL stream MAT value.
Note that this is for the $8D mask.
RBob.
sheachopper
Jul 31, 2019 11:27 AM
BumpaD82
Feb 26, 2016 02:57 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
