quick open loop question
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What car?
What ecm?
What mask?
It kind of helps to answer questions if u know what you are working on/with.
Every mask I have seen and used will still do everything it did prior regardless of u running open loops or not.
Most of what I do is 165 or 730 F body masks however others may vary, but more than likely not.
later
Jeremy
What ecm?
What mask?
later
Jeremy
NinjaNife
Aug 23, 2015 11:49 AM
