EBL, how do I get started?
Old Dec 17, 2006 | 02:56 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys, I have finally decided to jump into the world of tuning and I need a hand.I want to use the EBL for my tbi.What else is good to use with it?From what I can gather the ostrich is a must for this.I don't want to keep having to buy chips so I think the emulator is the right way to go.So what is a good combo to use?
Old Dec 18, 2006 | 02:25 PM
anybody?
Old Dec 18, 2006 | 02:31 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
The EBL and Ostrich are the way to go. Mine works flawless. After you get started you will be acquiring a WB02 as well.
Old Dec 18, 2006 | 02:57 PM
ericruhl's Avatar
Car: 77 CJ7
Engine: AMC 401 w/ 454 TBI & 8746 ECU (61)
Supporting hardware requirements are listed on the Dynamicefi website (see the "What else is required" section).
An Ostrich is not required, but it is very convenient for making rapid, repeated tuning updates. You can accomplish the same net result by reprogramming a chip, it's just more time consuming. If you use the suggested eprom chip, you need to buy only one chip. Eproms can be erased and reused with ease, the only catch is that you have to remove it from the ECU to reprogram it. This can be simplified by using a ZIF socket.
I opted for both an emulator and a burner so I could run on a chip during the times I'm using the emulator on a second vehicle. I also run a chip during extended periods when I don't plan to do any tuning so I'm not dependant on the emulator batteries / ribbon cable / etc.
MustangBeater20
Oct 29, 2022 09:20 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992Vortec
Aug 31, 2015 08:05 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
beast94
Aug 20, 2015 06:44 AM
