my 1st datalog!!! now what :)
Subscribe
Dec 23, 2006 | 10:38 PM
85tpi 870 ecm using winaldl to log a data file. could not get tunerproRT to work.
I now have the data in excell. I really dont know how to interpret it all that well. I seem to be rich off the line & in accell in the low MAF range & lean in the higher MAF & rpm range.
i'm trying to improve low end throttle response. seems weak & takes awhile on full accell to get the rpms & power going.
Do i need to address timing tables or MAF tables or what 1st????
thanks for some direction on how to get started on this. the datalog doesnt seem to have any ryhme or reason comparing the 02 versus int, tps, etc, i cant make any conclusions from it.
Reply 0
Dec 24, 2006 | 07:56 PM
I got tunerpro logs now too that i can post. I cant get load values in my data with my ads file im using for some reason & my scanner doesnt do it either. my scanner does record MAF readings, which i assume is load, but it never goes up over 100.
Reply 0
Subscribe
