highway mode with $0d mask
Old Jan 11, 2007 | 05:00 PM
getsideways's Avatar
well im getting my tune much better and blms are close no surging. im happy now with the way it runs. ive still got tuning to do but im going in the right directions. any way. haulin$$ mentioned that setting the bit at l400d is lean cruise mode. i would like too start fooling with this to get some better milage. can anyone help me understand it. the temp enable threshold is set at 150dec celsius if less than? that would enable the open loop afr table all the time. is this what i want? or what temp should i set for this to start working? can this method be used too get better milage and not loose performance when i step on it? thanks.
Old Jan 11, 2007 | 06:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Leaner is not always better!.
One item often forgotten, is that it takes a given amount of energy to push a car/ truck down the road. So while you might change the amount of TPS for a given cruise speed, the actual Pulse width might be the same. While the code often provides for leaning things out, that would suggest (to me) that the dynamic AFR was too rich.
To date the best MPG I've gotten was with a ~13.5:1 AFR.
The oil temp., was also reduced.
Old Jan 11, 2007 | 07:09 PM
also here is my latest bin with a log of some wot runs. it almost makes me nervous that i have no knock counts to speak of. im only running 87 octane fuel. i dont think i hear any pinging but truthfully i might not know it very well if i heard it. my timing seems kinda high. thanks
File Type: zip
Old Jan 11, 2007 | 08:56 PM
BHall71's Avatar
Car: 95 Silverado
Engine: TBI 350
Axle/Gears: 3.73 Detroit Truetrac
I have been messing with highway mode/lean cruise mode with my $OD and am getting somewhere a little at a time... I think. I will probably be posting some questions myself in a couple of days. Check out the other post here at this page: https://www.thirdgen.org/forums/diy-...ts-time-6.html
Hauln tells how to do it. Do you have a wide band o2? I really wouldn't suggest messing with highway/lean cruise mode without one.
I briefly looked at your datalog. You need to set your TPS to .53V when at 0%tps, this should get your WOT TPS to be something like 99.6%.
Brian
86White_T/A305
Mar 6, 2016 01:48 PM
ULTM8Z
Nov 15, 2014 10:28 AM
Lucid
Mar 7, 2009 07:36 AM
TRAXION
Dec 27, 2007 10:15 PM
BlackBird92
Jan 23, 2005 02:33 PM
