165 ECM $6E Tuning Links and Issues
Old Jan 21, 2008 | 12:38 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
TPI Basics
http://www.chevythunder.com/fuel%20i....%20pg%20B.htm
Beginners Guide to Tuning
https://www.thirdgen.org/forums/diy-...ng-tuning.html
Lower Thermostats and ECM Parameters
https://www.thirdgen.org/forums/tech...-persists.html
What are masks, Bins , .ECU .XDF files?
https://www.thirdgen.org/forums/diy-...ht=xdf+editing
https://www.thirdgen.org/forums/diy-...questions.html
DIY ALDL Cable
https://www.thirdgen.org/forums/diy-...able-need.html
1227165 ECM Upgrade
https://www.thirdgen.org/forums/tpi/...wrong-ecm.html
What is a good tune? (some good info here)
https://www.thirdgen.org/forums/diy-...good-tune.html
** Moates Mirror for BINS / Software Uploads and Downloads ***
http://www.gearhead-efi.com/gearhead-efi/
$6E Mask Specific Tuning
$6E Mask Basics and Bins
https://www.thirdgen.org/forums/diy-...i-hurt-my.html
AIR Disable
https://www.thirdgen.org/forums/diy-...-pump-air.html
https://www.thirdgen.org/forums/diy-...isable-6e.html
https://www.thirdgen.org/forums/exha...ht=delete+smog
Injector Size Change
https://www.thirdgen.org/forums/diy-...-new-tune.html
https://www.thirdgen.org/forums/diy-...signed-up.html
Disable EGR
https://www.thirdgen.org/forums/diy-...ght=egr+delete
https://www.thirdgen.org/forums/diy-...le-egr-6e.html
ARAP Long Crank Issue
https://www.thirdgen.org/forums/diy-...rank+arap+long
https://www.thirdgen.org/forums/diy-...alternate.html
VSS Disable ?
https://www.thirdgen.org/forums/diy-...ight=arap+code
VSS/Speedo Issues
https://www.thirdgen.org/forums/diy-...highlight=apys
Idle/Stumble/Rich Issue with Camshaft Swap
https://www.thirdgen.org/forums/diy-...ome-those.html
Highway Mode
https://www.thirdgen.org/forums/diy-...hway-mode.html
Tuning the MAF tables
https://www.thirdgen.org/forums/diy-...cm-32b-vs.html
Expanded $6E XDF file
https://www.thirdgen.org/forums/diy-...tion-file.html
General $6E Fueling and BLM questions
$32B vs $6E ( Fan Request - Cold Start Injector - Vats Disable )
https://www.thirdgen.org/forums/diy-prom/288471-32b-vs-6e.html[/urSl]
SA Total Timing Discussion (Post #21 for Rbob's Timing Lesson)
https://www.thirdgen.org/forums/tpi/...-your-tpi.html
Misc Tuning
Bosch III Injector (Possible Issue)
https://www.thirdgen.org/forums/diy-...or-sticky.html
https://www.thirdgen.org/forums/diy-...ctors-not.html
https://www.thirdgen.org/forums/diy-...gn-iii-pw.html
https://www.thirdgen.org/forums/tpi/...injectors.html
Old Oct 2, 2008 | 02:38 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: 165 ECM $6E Tuning Links and Issues
bump
Old Oct 2, 2008 | 03:44 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Good one
Old Nov 5, 2008 | 10:10 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
bump....
Old Mar 6, 2009 | 10:58 PM
Lucid's Avatar
ttt
Old Mar 7, 2009 | 07:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thread has been sticky'd under Chap 5, '165 ECM of the Tuning Guide Book...
RBob.
