arap 6e
Old Jan 21, 2007 | 07:43 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
arap 6e
looking at this bin,is there a rev limiter,top speed limiter. I see there is a fuel on/off at 255 MPH and a fuel on/off at 9800 and 10000rpm? Any spark cut off? Is this right,doesn't seem so. BTW reading this with an autoprom. Thanks!
Old Jan 21, 2007 | 08:52 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I adjusted the fuel cut off using the prominator. I haven't looked much into the ARAP bin file in awhile. I like that bin the only problem I had was my car wouldn't restart after I turned it off after it warmed up. I had to go into the tables and change the fuel pulse vs coolent temp settings
Old Jan 22, 2007 | 08:22 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It's right. GM didn't use the rev limiter, and I think only used the speed limiter on cars that got the lower-speed-rated tires. Most of us that modify our bins change the rev limiter to something realistic. To answer your question, there isn't a spark cut off, just fuel.
Glen
Apr 19, 2003 10:03 PM
madmax
31
Jan 7, 2003 04:15 AM
Mark 89Formula
Jun 25, 2001 10:20 PM
Grim Reaper
May 23, 2001 08:08 PM
P J Moran
Apr 20, 2001 06:11 PM
