highway mode
Re: highway mode
I believe your question was answered in a thread I started on hyway mode. Note spell hyway. I will see if I can find it. I believe it has to leave CL due to fact it is not stoich at 16/1. If CL BLM would rise to 160 or so.
Here it is: https://www.thirdgen.org/forums/diy-...hway-mode.html
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: highway mode
I think it's supposed to run lean on highway mode, and then it falls out after a certain amount of time (around a minute I believe, but that can be adjusted), this is probably to prevent overheating and is probably normal.
The fact that it goes to 0 is odd though.. How new is your O2 sensor?
Car: 87 Iroc
Engine: 5.7L TPI
Transmission: Built 700R4
Axle/Gears: 3.23 posi
Re: highway mode
Car: 87 Iroc
Engine: 5.7L TPI
Car: Anything that handles
Engine: 383
Axle/Gears: 3.25
Re: highway mode
Hope someone can shed some info on this question. I'm a newbie to programming, so I don't understand all the abbreviations, what the settings are for, etc. etc. But I have been playing around, and like people have said, it's the only way to learn how to do it. So, I basically have a '87 TPI set up, but not in a F-body. It's actually in a '41 Chevy coupe. 383 SB with al. heads, hi-flow Edelbrock manifold, hi-flow runners, 52mm TB, and a fairly mild cam. I'm going on a trip next week on old Rt.66 to Ca. from NY, and I want to enable Hyway mode for a little better mileage. I've read all the threads I could find on the subject, and I think I can get the chip burned properly. One thing is unclear to me. I don't have a electronic speedo, so the ECM doesn't read MPH-does it? So if it doesn't, do MPH settings for enableing hyway mode, or for that matter, any setting for any function in the bin, actually work when you set them? I just have the original speedo cable set up. Any info on this would be a big help in making me understand more on chip tuning. Thanks.
Car: check
Engine: check
Transmission: check
Re: highway mode
RBob.
Engine: 383
Axle/Gears: 3.25
Re: highway mode
Thanks RBob. I should have said, I am using the $6e code. Probably won't have time to get and hook up a vss before I leave. Will it still work?
Car: check
Engine: check
Transmission: check
Engine: 383
Axle/Gears: 3.25
Re: highway mode
RBob,
I don't understand what you mean (Not with the stock code. The MPH test is a branch if less then or same for no highway mode). As I said I'm a newbie to programing.
Can I enable it by setting the RPM, Lv8, and set the MPH to 0? Or some other way to fool the ECM?
Car: check
Engine: check
Transmission: check
Re: highway mode
If you want to patch the code then it can be done. And by patch I don't mean a change in a calibration parameter.
RBob.
Car: 1985 IROC-Z28
Engine: LB9
Re: highway mode
not the most elegant solution, but could set the MPH calibrations to 0, then change the BLS to BLO. total of 3 bytes changed. but the problem of potentially unwanted highway mode activation would be an issue...
Engine: 383
Axle/Gears: 3.25
Re: highway mode
OK. Thanks for the info. I was able to find a vss and ordered it overnight from Ca. so I should be able to get it hooked up and working before we leave next week. Will post how it works out.
Thanks again for the help.
Engine: 383
Axle/Gears: 3.25
Re: highway mode
Well, I got the VSS installed and worked on getting hyway mode turned on with a friends help. We couldn't get it to work, and maybe someone can tell me if this is why. When I put the car together originally, no vss. So to get the converter to lock up in 4th. gear, a single 12v. wire was run to the trans to lock the TCC. The question is, is there a signal requirement for 4th. gear lockup to the ECM for it to go into hyway mode? Right now, the way it's wired, there is no provision to signal the ecm when it's in 4th gear. Any ideas?
Thanks.
Thanks.
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: highway mode
HIghway Mode (HM) Mdoes not seem to be engaging for me. in EBL P4.
Are there option words that must be checked (or unchecked) as part of the conditions for HM to be met?
Are there items which when set can be too far out of range for HM to be active.?
Car: check
Engine: check
Transmission: check
Re: highway mode
Check the qualifiers, having the MPH enable threshold at 150+ MPH will do it. There is also the CTS & MAP thresholds, along with the in & out times.
RBob.
Re: highway mode
Thanks, I'll will double check all the entries again. Might have map too high?
Car: check
Engine: check
Transmission: check
Car: check
Engine: check
Transmission: check
Re: highway mode
RBob.
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
Re: highway mode
OK..I will look back at my datalog and see if it that occurs. I am running the ASDU3 bin that I believe you and a few others worked on along with the definitions file with the Hiway/ESC patch. If that matters?
Thanks for getting back to me
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
Re: highway mode
I attached my bin and the latest datalog and I do not see that the INT or 02 do anything out of the ordinary. I am leaning toward it not initiating. Let me know your thoughts.
Re: highway mode
Lots of good reading here. I was working out the settings for my engine then read the warnings about EGR. I don't have one. I do run a barn door kinda truck so any MPG help is appreciated. If I would only get 10% improvement, as EagleMark found on his "brick", then it might not be worth the effort. I don't normally see more than about 200 highway miles a month. I get about 11 MPG now. 10% would be just over 12. That's about 2 gallons difference per trip vs. the chance of burning out my engine.
Re: highway mode
I ended up enabling HLC today. I didn't think it was working because I didn't see the BLM freeze at 128. It was actually around 124. INT did freeze at 128. Weird. I knew it was working because the log file showed going into and out of Open Loop.
My last highway run showed an average of 15.1 MPG in the hack. This run showed 18.6 in the hack. Temps were good and no knocks.
Steve
Steve
Car: check
Engine: check
Transmission: check
Re: highway mode
RBob.
Re: highway mode
RBob, I have read that BLM will freeze. My logs showed INT freezing and BLM kept moving. It's opposite of what I expected to see in the log file. It does work, though and I am happy.
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
Re: highway mode
RedLeader289
May 28, 2019 01:47 PM
