PrkNeut light in What's Up Display
Car: 92 Firebird
Engine: 350 TBI/LT4 cam
Transmission: 700R
Can someone explain why the PrkNeut light comes on and stays lit after coming out of park?
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
that shows what the ECM is seeing from the P/N switch.
the ECM uses it mainly for idle speed, canister purge, & maybe timing & EGR control.
in park & neutral it should show one way, in any other gear it should show the other way.
Car: check
Engine: check
Transmission: check
The Park/Neutral input to the ECM should be grounded when in prk/neut. The in-Drive position is open, the input not tied to anything (manual trans is always that way). This is typical for many GM setups including the 3rd gen f-body's.
RBob.
RBob.
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
A little off topic...What kPa do you idle at? I have the same cam, I'm curious how it runs N/A.
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
