6299-7747 differences??
Old Mar 22, 2007 | 11:54 AM
90c350's Avatar
Hey i know that these are truck ecm's but could someone please tell me the difference between the two?? I got one from the wrecker and need to know if it will work. I currently have the 7747 and was wondering if the 6299 will work with some tuning?? Thanks for the help
Old Mar 23, 2007 | 10:20 AM
boatderek's Avatar
Re: 6299-7747 differences??
looks like 6299 is a 92-93 truck ecm. i didn't see any xdf or ecu files for it in diy-efi.org. means you will probably have a hard time doing anything but driving with it. unless somebody knows a site with bins and xdfs for it?
Old Mar 23, 2007 | 11:17 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Actually look on the Moates website. There is a 299 .ECU file in the User provided .ECU section, might be listed as the GM program name $99.
Old Mar 24, 2007 | 08:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '6299 and '7747 use the same hardware, only the firmware is different. The firmware is the BIN code that runs the engine.
RBob.
Old Mar 24, 2007 | 03:02 PM
90c350's Avatar
Thanks alot for the help guys. Once again getting great info from all of you!! I just wanted to make sure that it wasnt to different, because im doing an EBL upgrade and wanted to make sure that the harness will be plug and play with my current one. Also thanks for the heads up on teh bin file info. Thats going to come in handy real soon.
Old Oct 26, 2007 | 07:28 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
is there any adrvantage to swapping to a 7747 from a 6299? my 92 C1500 has one in it stock, and i've got a 7747 sitting in the garage.
Old Oct 26, 2007 | 09:06 PM
90c350's Avatar
I would have to say that after learning how to tune and chip burn that there is probably no difference between the 2 ecm's. But if you plan on doing some mods to your engine and get into chip tuning, then the 7747 would be the way to go, do to the fact that there is alot more support when it comes to programming. I hope this answers your question's???
Old Oct 27, 2007 | 12:44 AM
i gathered that there was more support and experience tuning the 7747. i was looking for a hardware or programming difference why one was better than the other, just out of curiousity.
Old Oct 27, 2007 | 01:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Actually, I have the full hacks of BOTH ecms on my desktop at home. With the Hacks you can make full DETAILED XDF files of both ECMs. That makes them both equal when it comes to support. That being said, I like the 299 better. It eliminates the VE adder table with a full VE table from 0-5,000 ish rpm and has idle compensation spark advance terms that help smooth rolling idles easier.
Old Oct 27, 2007 | 02:24 PM
90c350's Avatar
That sounds good fast but where do we find a good xdf file that already has the hacks done?? IF we are not capable of doing the hack our selfs its kinda nice to use the 7747. But I do have an extra 6299 in the shop and that ve table and idle program would be nice to use.
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
