Decreasing startup time?
Old Mar 29, 2007 | 11:59 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
I tried to search and either search is broken, or I can't, as no search word returns results.
I suspect this has been covered, so is there a consensus on whether or not changing the number of distributor reference pulses required to fire to decrease startup time is good or bad?
It's not a faulty fuel pump relay I'm dealing with, starts aren't unreasonable, just longer than they have to be based on the settings in the bin.
I suspect this was done by GM to get some oil flowing before the load from running hits the bearings, but I played around with it, and the engine will certainly start much faster if you let it.
Specs in sig, if it matters.
Old Mar 30, 2007 | 12:15 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Re: Decreasing startup time?
If i remember right, you may be useing a version of ARAP... my first 8-9 cells in the "Crank Fuel PW Multipliler Vs. Ref. Pulse" table were zero, put a little in them and see what happens....
mulitply anything by zero and what do you get?
ref. pulse- is something like crank revs
Old Mar 30, 2007 | 12:47 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Yeah, that's what I had changed to see how fast it would start. It certainly makes a huge difference, my question is why did GM not just set the system to start faster in the first place?
Old Apr 1, 2007 | 12:33 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
They want to avoid electrical noise from causing injections at a bad time.
They want to get the starter moving the engine a little faster before injecting to reduce flooding chance.
It's only 2 revolutions of delayed start.
A little extra oil pressure is good too.
And just see if it starts on the fumes in the manifold.
It helps ensure the operator really desired a start, rather than a bump, to avoid flooding or starting.
All possible, some more probable.
bamaboy0323
Sep 3, 2015 06:07 AM
midias
Aug 22, 2015 01:42 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
