single fire and double fire
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
whats the difference between the single fire and double fire injector constant? i've been told when i change one, i should change the other to the same value........ what happens if i put them at different values? advantages? disadvantages?? thanks!
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: single fire and double fire
No reason to have them different (your injectors don't change flow rates magically)
Different may cause surge if it switches between modes.
The right way to fix a difference between injection modes is the PW offsets.
ohhhh alright, ill change it back then haha
skinny z
Oct 5, 2015 06:23 PM
