How can I idle in open loop?
Old Apr 1, 2007 | 09:26 PM
Blazin4x4's Avatar
Car: 1988 Chevy silverado K5
Engine: 350 bored .030, crane cams hyd bluprint l-79 cam 447 lift 272 dur, camel hump heads port and polished 1.94 1.50, afterburner headers and y pipe, holley 670 cfm tbi, holley projection dual plane manifold, accel high pressure fuel pump, 3 inch exhaust
Transmission: 700 r4 with corvette servo and shift kit.
I know it invovles changing some delay paramaters but which ones and what do I change them to?
I'm running a 7747 with the amur bin and the 7747.mine ecu file for an .xdf.
Old Apr 2, 2007 | 08:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: How can I idle in open loop?
Here are the values GM used in one of the BBC open loop idles:
Code:
; OPEN LOOP IDLE CALIBRATIONS
LD29E:  FCB  10          ; 10 MPH, OPN LP IDLE THRESH
LD29F:  FCB   6          ; 2%, OPN LP IDLE THRESH TPS
LD2A0:  FCB  38          ; 950 RPM, Open loop RPM thresh IDLE OFF
LD2A1:  FCB  56          ; 1400 RPM, Open loop RPM thresh IDLE ON
LD2A2:  FCB   0          ; 0 Sec's, Open loop IDLE AFR Ratio enable TIME DELAY
LD2A3:  FCB   0          ; 0 Sec's, Open loop IDLE AFR Ratio TIME DELAY
LD2A4:  FCB 140          ; 14.0 Open loop AFR MAX AT IDLE
The BIN address is as shown without the leading 'LD' . So the first parameter is at BIN addy $29E. The values are shown as they are in the BIN, but in decimal. If these parameters are not in the ECU/XDF file, convert the values to hex and use the Hex Editor to enter them.
RBob.
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
