Possible BIG problem => HELP !!!
Old Apr 6, 2007 | 08:31 AM
Geut's Avatar
Engine: 350TBI
Axle/Gears: 3.42 powertrax
Hello,
I think I have a huge problem.
I changed the chip without disconnecting the battery.
And now the car woun't start annymore.
It ran fine before.
Could it be that the ECM is broken ?
How can I test it ?
Thank's
Dieter
Old Apr 6, 2007 | 08:54 AM
ULTM8Z's Avatar
Re: Possible BIG problem => HELP !!!
I don't believe you need to disconnect the battery to change the chip. I do that all the time. Though, you have to have the ignition off or you could damage the chip.
Try unplugging the ECM, leave it for about a minute, and then plugging it back in.
Old Apr 6, 2007 | 09:24 AM
Geut's Avatar
Engine: 350TBI
OK,
I can start with the chip removed, make a litle trip.
When I replace the chip, it woun't start annymore.
I tryed the stock chip and 2 custom's, all the same.
I am tinking that it could be possible I didn't even turn off the ignition.
So I wil now try to burn the chip again, maybe this wil help.
Gr.
Dieter
Old Apr 6, 2007 | 10:17 AM
Geut's Avatar
Engine: 350TBI
It seems to be solved.
I erased the chip and burn the bin on it agean.
It runs like before.
I probably had the ignition on while changing chips.
Think my stock chip is pretty dead.
Thank's for help.
Gr.
Dieter
Old Apr 6, 2007 | 04:25 PM
ULTM8Z's Avatar
Come to think of it, I think I remember doing that once many moons ago and yes, I had to burn a new chip.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
