From serious Lean to Pig Rich
Old Apr 17, 2007 | 06:28 PM
mk10842766's Avatar
Hopefully a quick question for all of you...I scanned my car two days ago, and my blm's were in the 148 to 160 range almost across the board. Took it for a drive yesterday, and scanned it, and the BLM's were 108 almost across the board. No changes, just sat overnite. What would cause this!!? I did overhead a bit last week, when I lost a water pump, but water pump, hoses, thermostat and radiator cap were all replaced. Scanned car after the changes, and it still showed 148-160 across the board, now this. Help please. Car is an 85 vette, running $6E on a 165 ecm...no motor mods, other than 1.6's....intake opened a bit, and a 3 inch exhaust, with headers...
Cheers,
Michael
Old Apr 17, 2007 | 07:50 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: From serious Lean to Pig Rich
Head gasket could have been damaged, and the antifreeze poisoned your O2 sensor. Hope not though!
Check your coolant sensor for proper readings.
Old Apr 17, 2007 | 08:12 PM
randy4762's Avatar
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Wow , I can't believe the same thing happened to me last week. I noticed that my cooloant temp read 158 on tunerpro and 195 on the fact guage. Weird right....well I had just filled up on coolant and the system hadn't burped yet. Then I realized the temp in tunerpro was in celsius! That means it was actually reading 316.4. It must have been a steam pocket!
Could this be what you were seeing? If it goes away after the system burps, maybe its the same thing.
Just a thought.....Randy
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
