Wideband 02 Options
Old Apr 17, 2007 | 04:25 PM
Desert86Roc's Avatar
Wideband 02 Options
Has anyone replaced the narrowband 02 (heated or unheated) in their setup with a wideband that has a narrowband output option?
If you have:
- What model(s) did you purchase and did you run into any issues converting?
- Did you leave your sensor in the driver side collector, or did you locate it after the "y"?
Additional info: SBC 406, with HSR & 730 ecm
Thank you
Old Apr 17, 2007 | 04:30 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: Wideband 02 Options
http://www.moates.net/product_info.p...roducts_id=103
No significant issues.
Mounted sensor in stock location
Old Apr 17, 2007 | 04:36 PM
firstfirebird's Avatar
^^^Same here, but my V6 already had it at the end of the y-pipe.
Old Apr 17, 2007 | 04:40 PM
In the above recommended setup, were there any special wiring considerations for using the wideband output -> narrowband input?
Thanks again for the suggestion.
Old Apr 17, 2007 | 08:26 PM
randy4762's Avatar
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Desert86RocHas anyone replaced the narrowband 02 (heated or unheated) in their setup with a wideband that has a narrowband output option?
I have been considering the same thing. I thought moving to after the y would better monitor both banks? And since the new sensor is heated, being further downstream shouldn't matter? I know the innovate LC-1 has 2 configurable outputs plus the digital output. It should output narrow band fine as long as you remember to ground it the way described in the directions. The voltage reference to ground won't be right if the new wideband controller isn't grounded at the sensor ground at the ecu.
That is if you want it to be as accurate as possible. Which can only mean better
o2 response time, gas mileage, and more power! (When running the AFR's close to the ragged edge, or running alot of boost)
What do you guys think?
Randy
Old Apr 17, 2007 | 09:18 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
I use Zeitronics Zt-2 for WBO. Unit is very fast for data logging and provides multiple analog inputs. In addition, it has NBO output which can be used with ECM. I have not integrated Zt-2 with ECM just yet, but probably soon.
http://www.zeitronix.com/Products/zt2/zt2.htm
//RF
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
efiguy
Sep 27, 2015 01:30 PM
