Idle SA setting
Old Apr 23, 2007 | 03:08 PM
91chevz71's Avatar
Idle SA setting
So, My truck seems to idle the best with approx 30 deg of TOTAL timing, as displayed on my computer. The BLM/INT is rock solid at 128/128, so just for kicks set it to idle about 26 to see what would happen and the INT started to descend to about 120. Setting the SA for about 34, the INT climbed to about 134. No knock counts at all during any of this, except for startup/shutdown. Both changes increased roughness of idle. Setting the total timing to 22 made the truck BARELY run. When I set the base timing, I just set it to what made it the smoothest, not really going for a predetermined value, and it ended up being 11 deg BTDC. I guess you gtta give it what it wants... Does that (30 deg) sound like too much timing at idle to you guys?
Thanks,
Mike
Old Apr 23, 2007 | 03:45 PM
Ronny's Avatar
Re: Idle SA setting
i think fast355 just posted to consider hook up vac gauge or manually turn dist. and set for idle SA to give max vacuum. my engine is at 19 deg and 15 on gauge. i think same could be done looking at lowest MAP. i think i was as high as 23 and low as 16 for SA.
Old Apr 23, 2007 | 03:48 PM
91chevz71's Avatar
Re: Idle SA setting
Sounds like that will help things. right on guys.
thanks again
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 15, 2015 01:17 PM
