CAN YOU TUNE A MASS AIR FLOW SYSTEM FOR BOOST??
Old Apr 29, 2007 | 01:14 AM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
JUST WONDERING IF I COULD TUNE MY MAF FOR BOOST, I WANT TO RUN ABOUT 6PSI. .THANKS
Old Apr 29, 2007 | 02:29 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: CAN YOU TUNE A MASS AIR FLOW SYSTEM FOR BOOST??
It's possible to make it work good enough for most people. But, it's not boost friendly software.
Some key points:
MAF will max out quickly
Raise the max Airflow vs RPM table to 255 everywhere
Spark will have to be compromized - set the LV8 208 column to boost friendly spark advance
LV8 will max out off the table
"Boost" won't be detected at all, just have to kind of assume when it's boost
Definitely lower the TPS threshold for PE fuel
Give it plenty of PE fuel, and more at higher RPM as MAF maxes out
Give it NO PE spark
Make sure your fuel pump is bigger and better than stock
Make sure your injectors can flow enough fuel for naturally aspirated hp + boost hp + wasted hp for turning the blower. Basically - figure BSFC = 0.55, and whatever hp is expected
Run some cooler plugs
Run premium fuel
MUST tune PE with a wideband
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
bryan623
Aug 10, 2015 11:33 AM
