Anyone have the AWFY code?
Old Apr 29, 2007 | 02:26 PM
ULTM8Z's Avatar
I started tuning on my friend's 305 TPI/auto car who changed from 19lb/hr injectors to 24 in anticipation of dropping in a 350.
I don't have the hardware to read the memcal directly, so I found AWFU online and started with that.
Anyway, Kevin and Don were absolutely correct in my last thread on this subject. I really had to tweak the fuel tables to get back 128 in addition to changing the injector constant.
I know AWFU is close, but I want to use the correct broadcast code so he doesn't get dinged at the smog station when they scan the car.
Old Apr 30, 2007 | 11:34 PM
ULTM8Z's Avatar
Re: Anyone have the AWFY code?
ttt...
Anyone?
Old May 1, 2007 | 08:16 AM
Z69's Avatar
Z69
Since when do they scan an obd1 car in cali?
Have you looked around the electronics department at Fry's?
I'd think they would have a dbl male header you could shorten to work.
Old May 1, 2007 | 01:42 PM
ULTM8Z's Avatar
That's just it. I don't know. I've never smogged an OBDI car (my 71 with the 1990 GM TPI system is smog exempt).
I'll ask my friend if he's ever had them scan his car...
Old May 1, 2007 | 06:47 PM
w/t1500's Avatar
Car: 93 W/T1500
Engine: 350 Vortec TPI
Transmission: 4L60e 2000 stall
Axle/Gears: 3.08
I have AWFY.
File Type: zip
Old May 1, 2007 | 07:00 PM
ULTM8Z's Avatar
Awesome!!!!
Old May 2, 2007 | 08:28 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Use this (assuming the target car is a 730) to download the bin via the ALDL port: https://www.thirdgen.org/forums/diy-...ght=nvsram+gui
Could could always just tweak the promid in your AWFU bin to whatever it is for AWFY.
Old May 2, 2007 | 05:39 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Be careful with THAT AWFY if it originally came from diy-efi.org. That bin is corrupted and shows it being "E7" as the calibration ID - which does not exist. I have it and didn't give it for that very reason.
BTW, it is highly unlikely ANY smog inspector will try and verify a particular bin/memcal for a particular make of car. GM (and other manufacturers) constantly release NEW calibrations (ie. superceed) for various cars.
When a customer complains of "driveability issues", dealerships will check if a particular memcal was superceeded with a new memcal and then replace it to see if it cures the problem. So a person can have a memcal that never came with the car originally.
What they are more likely to do, is review the memcal (if they actually want to drop the computer and open it up - again, highly unlikely) and insure it has the original silver sticker on the eprom window and make sure it doesn't look like it has been tampered with.
In all honesty, this sounds like a lot of worrying about nothing.
Old May 2, 2007 | 06:39 PM
ULTM8Z's Avatar
When I scan the car, I can read the PROM ID, which then translates back to the broadcast code. THat's what prompted me to think about it. But it sounds like it's much ado about nothing- so I won't worry about it.
Old May 4, 2007 | 02:04 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You can change the prom ID in the chip easily to match something else. But I've never seen a smog tech plug into the ALDL of an OBD1 car.
Old May 4, 2007 | 08:38 AM
ULTM8Z's Avatar
Glad to hear it!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
