quick EBL / WB question
Old May 14, 2007 | 04:47 PM
91chevz71's Avatar
Will the VE learn feature (with WB selected instead of BLM) continue to function into PE? I'm guessing not, but just askin
THanks
Old May 14, 2007 | 05:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: quick EBL / WB question
It will VE Learn in PE mode when the ECM is in open loop. The BLM also needs to be 128, which the default is each time the ignition is keyed-on. If closed loop is in affect then it won't learn from the WB.
RBob.
Old May 14, 2007 | 06:03 PM
91chevz71's Avatar
Thanks again Rbob!
Mike
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
