power loss?
Old May 22, 2007 | 04:27 AM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
power loss?
i have a basicly stock 350, 700r4 auto transmission on a 1991 camaro. When i had the 87 harness in the camaro i could burnout like no tomorrow from first through second and when not burning out and i hammerd on it and it would shift from first to second it would spin the tires also. now with the 91 SD harness it no longer burns out and rarely chirps the tires when shifting into second. Attached is the Data file from datamaster 8Dv351 of my car, im just now learning and reading about tuning and have all the tools to do it. Any sugestions??
so far i have been talking to lou who has been a great help, he said to post up here and see what others think..
he said this..
Looking at the data, it looks like your spark retard is kicking in for some reason. But the knock count does not go up, that's strange. I compared it with my acceleration data and mine shows spark advance of up to 40 degrees while you're staying at 20 degrees which would definitely account for some loss of power.
uploaded my uni file inside the zip folder
anything will help!! thanks in advance
Old May 22, 2007 | 04:30 AM
tourville's Avatar
Car: 1991 Camaro RS
Re: power loss?
file attachment
File Type: zip
Old May 22, 2007 | 06:25 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: power loss?
so you converted a MAF car to speed density? did you get the 350 knock module/chip ? did you change the knock sensor to a 91+ 350? they are different then maf cars
Old May 22, 2007 | 11:12 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Re: power loss?
Sorry, your zip file does not appear to be a valid archive according to winzip
Old May 22, 2007 | 11:27 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: power loss?
You'll need to clarify what hardware you have.
ECM # ?
Memcal/BCC #? AUJP or what ?
How did you have an 87' harness in a 91 Camaro?
Background story... Could have alot to do with current events.
There's no files there so I can't see it either.
Old May 22, 2007 | 06:59 PM
tourville's Avatar
Car: 1991 Camaro RS
Re: power loss?
i had a 91 v6 3.1 cyl and bought an 87 350 with the wiring harness + cpu.. and cut up the 87 harness to match 91 pins etc and make it work.. did not touch the interior 91 side of the harness, picked up a 91 350 harness + ecm and put it into the car, no i have not yet changed the knock sensor yet will be doing that this weekend most likly. but it is a 91 ecm and 91 chip. as far as the #'s etc ill get them either tonight or tomorrow for you
Old May 25, 2007 | 03:34 PM
tourville's Avatar
Car: 1991 Camaro RS
Re: power loss?
sorry about getting back to this so late! worked thursday from 6am till friday morning 12:30 night time then had to get up for work at 6 today(friday) :\ what a drag! well the Serv NO is 01227730 and other numbers on the tag were 860721 M020760649
tomorrow i plan on changing the knock sensor and ordering my speed sensor
Old May 25, 2007 | 03:39 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Re: power loss?
thats your problem right there, you didnt change the knock sensor, the ecm is probably retarding your timing, the maf and sd knock sensors are different
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
