Which EEPROM?
Old May 23, 2007 | 04:42 PM
89s154.3's Avatar
Which EEPROM?
So i have a 7747 $42 and have access to a programmer. Which EEPROMS do i need?
Old May 23, 2007 | 06:18 PM
gofast51's Avatar
Re: Which EEPROM?
The first thing I would suggest is to read. Start with the stickies right above the posted threads. This is a question you could have had an answer for already. The 7747 takes a 2732 Eprom. to use a EEprom requires a conversion to your ECM. You can also READ about that conversion and where to buy.
Old May 23, 2007 | 11:38 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Which EEPROM?
It is difficult to find a 24 pin EEPROM that will fit into your ECM. What most people do is install an adapter board that allows you to install a widely available 28 pin EEPROM made by SST. The part number is 27SF512 and you can get them from www.mouser.com for about $1.50 each (cheap).
rsilver
Apr 28, 2004 01:53 AM
ski_dwn_it
Oct 5, 2001 02:19 PM
okfoz
Jun 21, 2001 10:11 PM
Kevin91Z
52
Mar 31, 2001 10:59 AM
