Laptop can't connect to ALDL port...SES light stays on!?!?
Old Jun 2, 2007 | 02:38 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
With a new motor and a chip burned (3 chips) by a fellow member to allow me to at least start the car I find that my laptop won't connect to the cars computer. I have the USB ALDL cable and I sent one back thinking it may have been bad but they said it checked out fine and sent a new on anyway. My computer recognizes the serial converter just fine.
I tried connecting via TunerPro and also through HyperTerminal with no results.
Also, my SES light stays on constantly when the key is in the ON position as well. I read in another thread these may mean a non responding computer?!? I had the car started prior to the rebuild with the same exact problem.
Any ideas here??? I did a good amount of wire lengthing to clean up the bay as well as added an MSD box and moved the battery to the rear.
Old Jun 6, 2007 | 01:38 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Re: Laptop can't connect to ALDL port...SES light stays on!?!?
I had that problem a couple times with TP. I recommend two things: check that you have the correct (and a good) data stream definition file and check your ALDL setup on TP on the laptop. The settings are different for the USB vs serial "Tools" - "Preferences".
Check the post about solid SES light, Chip isn't even working...
Good luck
Old Jun 6, 2007 | 10:32 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I'm not getting anything on HyperTerminal either (but I don' know if I'm setting it up correctly) and I turned my kill switch off erasing any codes. BUT, last time the motor was started I didn't have any codes. THe 305 ran too well to have a bad comp but I guess over the car sitting something could have happened. I read the thread about the solid SES light...
I'm just going to carb to see if all my problems really are in the EFI or if I have shortblock issues. This has been two headaches after two others.
Old Jun 6, 2007 | 11:19 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
BTW...I removed my adapter and replaced it with the stock 305 chip only to have the SES light continue to stay on.
TheJoeY88
Dec 31, 2016 07:30 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
