quick question about $6E
Old Jun 25, 2007 | 09:32 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
i noticed this is the mask for 90and up cars. mine being an 88 with MAF will i need a SD MAP sensor now, or just eliminate the cold start and remain using my MAF sensor?
Old Jun 26, 2007 | 12:48 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: quick question about $6E
6E is for the 89 5.0 & 5.7 TPI.
8D is for 90 & up TPI.
with 6E, you need the MAF.
the cold start injector isn't used by 6E, most people cap off the fuel line for the cold start injector, for now you can just unplug the electrical connector on it.
Old Jun 26, 2007 | 12:43 PM
Axle/Gears: 4.10
ok thank you. i read the chart from gm wrong.
Old Jun 26, 2007 | 04:26 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Hi,
So this would also be a good mask for a 87 350-A4 car
to start with.
Was going to start with 32B??
Whats the difference between 32B and $6E other than
the year from 87-89? Timing??
Didn't mean to hijack thread but was on the subject was going to post.
Just getting started with my APU1 and TP RT.
Been running a PCFormless starter chip that runs pretty
darn nice but needs a few changes.
Old Jun 26, 2007 | 07:57 PM
DENN_SHAH's Avatar
6E was the latest offering from GM, it does away with the cold start injector.
as far as i know, there is more info on 6E than 32 or 32B, i believe some of the tables are setup better also.
Old Jun 27, 2007 | 05:30 PM
jaykar's Avatar
Thanks,
Thru the years got pretty proficient with the Carters
Rochesters,Holleys and distributor setups for different
setups.
Now going to have to use the keyboard to set it up to
run FI
Been doing alot of reading but Lite Bulb hasn't come
on yet. Think I have the basics
Later
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
