Your lag filter settings
Old Jul 26, 2007 | 11:05 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Thought I'd throw this out. During the tuning of my modded Xfire w/EBL, I found that I liked the way the motor behaved when I minimized the lag of various filters. What have you guys done?
Old Jul 27, 2007 | 01:08 PM
91chevz71's Avatar
Re: Your lag filter settings
which ones? could you please describe your changes and results?
Old Jul 27, 2007 | 01:25 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
With EBl, there are several filters for TPS, MAP, VAFP Regulator etc. On my modded motor, it appeared to run smoother if most of these filters were set to allow the sensor inputs to more quickly affect ECM calcs.
Old Jul 27, 2007 | 01:37 PM
91chevz71's Avatar
I am also EBL equipped- did you mess with the AE filters at all?
Old Jul 27, 2007 | 01:54 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Yes. As a general rule, I found that a modded motor wanted quicker response and reaction to changes than a stock motor. You need to start slowly till you get some idea of how the motor is reacting to the change you made and then continue changing until you overshoot. Then back off.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
