question about a chip
Old Aug 1, 2007 | 08:16 PM
BlkLB9IROC's Avatar
when you install an aggresive chip should you advance the timing???
Old Aug 1, 2007 | 08:34 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: question about a chip
Hello, welcome to quantam physics class. Bathroom is down the hall on the right.......
pardon my humor, but on this board we actually burn our own chips and have the ability to change every parameter in the chip. The short and sweet answer to your question is tha tyou shouldn't buy an over the counter chip. They are a waste of money and you can get most of the benefit by simply advancing the timing manually.
When you can tune your own chips simply knowing what your base timing is set to is all that is needed to start tuning.
Old Aug 1, 2007 | 08:35 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
no. if you bought an aftermarket chip, they probably turned the timing up too much already.
the base timing needs to be properly set to what it is set to in the chip.
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
What's an aggressive chip? In most cases you should keep your distributor set at the stock value (6 degrees for most of us) and adjust your spark tables for more/less advance.
If you're getting your tune from elsewhere, keep your distributor at stock, since this is most likely the setting for which they created the tune.
Even better, tune it yourself!
EDIT: holy cow, in the time it took me to write that, there were three other replies!
Old Aug 1, 2007 | 08:55 PM
DENN_SHAH's Avatar
[QUOTE=Mangus;
EDIT: holy cow, in the time it took me to write that, there were three other replies![/QUOTE]
Old Aug 2, 2007 | 12:06 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
As mentioned above - you ALWAYS leave the timing to the stock setting because all spark advance is handled inside the tables of the eproms.
As this post is related to tuning your OWN eproms, I have to close it.
Sorry.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
