Scan Tool Data Values from RamJet Manual...
Old Aug 12, 2007 | 10:36 AM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
I was comparing the values in my 730 ECM with the expected values in my original RamJet 350 Manual. Some of the values in the RamJet are as follows:
TEST CONDITIONS
Idle/Warm Engine/ Closed Throttle/ Neutral
MAP = 29-48 kPA / 1-2 Volts (depends on vacuum & barometric press)
TP Sensor = 0.70 - 0.80 volts
TP Angle = 0-2 %
Spark Advance 6-26* (Varies continuously)
IAC = 20-40 Counts
IAC Throttle Follower = 20-60 Counts
These are a bit different than what I've ended up with after editing my BIN as mentioned in the post below:
https://www.thirdgen.org/forums/diy-...t-my-idle.html
Should I be shooting to approach the values in the original RamJet 350 MEFI program? I must note that the original value to set timing in the RamJet 350 system is 10* @ 1000 RPM.(in case that matters).
I also have a question; what is it that determines engine RPM when the timing lead is disconnected?
Old Aug 12, 2007 | 02:19 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: Scan Tool Data Values from RamJet Manual...
Originally Posted by silvernblack
IShould I be shooting to approach the values in the original RamJet 350 MEFI program? I must note that the original value to set timing in the RamJet 350 system is 10* @ 1000 RPM.(in case that matters).
I would only consider those to be a "starting point" and adjust from there. I would NOT expect your "final tune" to remain there.
Falcon50
Aug 22, 2020 03:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bjpotter
Oct 4, 2015 07:48 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
