EGR at low RPM, lean burn / highway mode?
Old Aug 19, 2007 | 10:25 PM
91L98Z28's Avatar
Car: Z28
two questions...
1) has anyone played with running EGR at low RPM's (around 1200)? I recently failed a smog check and I'm pretty sure it's due to two factors:
a) the tech ran the car in 2nd gear at 15mph resulting in ~ 1200 rpm,
b) after an extensive datalog, I discovered there is little to no EGR that low.
I am going to try and suggest to the tech that he keep the car in 1st gear for the 15mph portion of the test, but I'd like to have a back up plan (run some EGR down at 1200rpm around 40-50kpa).
I'm curious how much EGR I can run or if there are going to be other tuning issues.
2) I noticed in the datalog that my commanded AFR at one point went quite lean (15.1:1), learn mode went off, and port AIR was on, and O2 was stuck < 100mV with no BLM/INT updates. This went on for many seconds.. Is this normal? I've never spotted this before, and I thought highway mode was completely disabled in production GM BIN's (I'm using AXXD). I'll have to re-check everything, I certainly don't remember enabling it...
thanks!
Old Aug 20, 2007 | 12:20 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: EGR at low RPM, lean burn / highway mode?
HWM is enabled in some bin, check yours...
Sorry cant help you on the EGR stuff.......
/N.
Old Aug 20, 2007 | 11:37 AM
discostu's Avatar
Which portion of the test failed you? Was it the NOx or HC or CO?
If it was the NOx, then you should look at your EGR working at that RPM. Or knock down your spark a couple degrees. (Or eliminate hiway spark, if it's enabled)
If it wasn't the NOx, I'd be looking more at your fuel. Get it smack on 14.7 in those cells and you should be ok.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
E Rod
Aug 28, 2015 05:17 AM
jbd1969
Aug 17, 2015 07:06 PM
Jake_92RS
Aug 17, 2015 09:42 AM
