data logging
Old Aug 27, 2007 | 10:45 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
data logging
I have heard some laptops (maybe the OS?) can't do live data logging?
My car is running Tuner Pro R/T.
thanks
Old Aug 27, 2007 | 11:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: data logging
Tunerpro R/T is the real time datalogging software. with a proper cable and connection to the ALDL port, you should beable to datalog
the only laptops that cant do it are ones without usb ports to plug in the cable but i do believe you can get adapters for other ports on the computer.
Old Aug 27, 2007 | 11:44 PM
90c350's Avatar
Re: data logging
YOu need to make sure that you have an old laptop that has at least 400gb I beleive. When I first started out I had to old of a laptop and it would not correclty run the usb card that I got nor would it run fast enough to keep up with the program for dataloging. I think that anything that is about 2000 of newer will have no problems.
Old Aug 28, 2007 | 01:06 PM
1badz71tahoe's Avatar
Re: data logging
400MHZ.
I have an 8 year old laptop that's 450 MHZ.
Old Aug 28, 2007 | 01:20 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: data logging
Just as long as the laptop is somewhat fast and has USB you should be good to go. With the older laptops, it might be better to use the serial if it doesnt have USB. That will require the construction of a 2-transister cable. Not hard, but an extra step.
With the USB, the only issue I ran into was having to manually assign some settings so the USB would be within range for tunerpro to recognize it.
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
