Best Way to Tun Tip-In with $6E
Old Sep 7, 2007 | 11:11 AM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I've got a tip in hesitation and need to add some fuel. What is the best way to do this with $6E?
Thanks,
Old Sep 7, 2007 | 08:12 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Re: Best Way to Tun Tip-In with $6E
there are a few tables with Accel enrich in the name, in tunerpro acceleration enrichment factor vs change in lv8 is the main one. you can also adjust a couple constants for how much tps change or lv8 change kicks you in to acceleration enrichment mode
Edit: oh yeah, I'd double check your timing adjustments too, seen many tip in problems that were spark and timing related that huge amounts of time were spent on fueling before it was figured out.
Old Sep 11, 2007 | 06:00 PM
Duts87ss's Avatar
Pretty sure my timing is where it should be, but I'll double check. Thanks for the reply.
Old Sep 11, 2007 | 08:23 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
There's several tables that are not in the common $6E xdf. I've posted my ammended xdf several times if you can find it again. If not, pm me your email address.
Otherwise, you also need to make sure your MAF tables are good enough (have you modified your MAF, or is it a large cam?).
Old Sep 12, 2007 | 04:45 AM
Duts87ss's Avatar
My email at work is dustin.little@ngc.com . I'd appreciate the the new .xdf, Thanks.
I havent modified the MAF tables at all; the engine is an unmodified Goodwrench 350.
Thanks again guys, I'll try to use the advice I get this weekend. Overtime this week means no afternoons with the car.
Old Sep 12, 2007 | 07:02 PM
edfirebird's Avatar
Matt could you please also email me a copy of your xdf. I am suffering with simular woes.
Thanks in Advance,
Ed
Edfirebird68@aol.com
Old Sep 19, 2007 | 02:53 PM
edfirebird's Avatar
Ed
funstick
65
Feb 26, 2013 09:26 PM
funstick
May 29, 2011 01:16 PM
peruvious
Car Audio
Nov 2, 2003 01:33 PM
funstick
69
Apr 28, 2003 01:35 AM
funstick
34
Sep 25, 2002 03:40 AM
