Open Loop Tuning - AFR % Change vs Load
Old Sep 14, 2007 | 08:19 AM
87 Vette Owner's Avatar
Car: 1987 Corvette
Engine: 383 ci
Transmission: ZF 6 Speed
Axle/Gears: 4.10 Dana 44
I am tuning my '87 vette (165 ECM, $6E, MAF) in 100% open loop. I've been data logging AFR vs MAF voltage to analyze areas that are rich vs areas that are lean.
I started with a stock APYP bin, and in TunerPro RT, there is a table called "Open Loop AFR % Change vs Load". It lists all the Load figures on the left (going from 0 to 256) and the corresponding AFR % change on the right. For very light loads, there is zero percent enrichment added. But, for medium and heavier loads, there is anywhere from 4% to 13% enrichment. What was GM's original intent for this - to ensure a safe, rich mixture in open loop at heavier loads?
Since I am tuning in open loop 100%, should I zero out these open loop enrichment tables and just tune using the MAF tables (voltages) and AFR? I'm thinking these enrichment percents might throw off some of my readings and make it more difficult to get the MAF tables dialed in properly.
Thanks!
Dan
Old Sep 14, 2007 | 09:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Open Loop Tuning - AFR % Change vs Load
Adjust the MAF tables so that the WB reported AFR matches the ECMs commanded AFR.
I wouldn't zero out the enrichment tables, 14.7:1 may be a tad lean under heavy throttle.
RBob.
Old Sep 14, 2007 | 09:40 AM
Car: 1987 Corvette
Engine: 383 ci
Thanks RBob! In PE mode, (set to engage at 70% TPS), I've tuned the PE enrichment tables by RPM to hit 12.5 - 13.0:1. You're saying when not in PE mode, but at heavier throttle (55% - 69%), with heavier loads, I should still be a little richer than 14.7:1 (hence leaving the tables as is), correct?
Old Sep 14, 2007 | 01:52 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes.
RBob.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
jbd1969
Aug 17, 2015 07:06 PM
355tpipickup
Aug 13, 2015 07:35 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
