27sf512 wont verify
Old Sep 17, 2007 | 10:25 PM
kansan's Avatar
Car: 90 c1500
Engine: 383
27sf512 wont verify
I am trying to program a 27sf512 with a pp2, $0D. The problem I am having is after I erase the chip, load the buffer, and program, the chip wont verify to the buffer. Bufffer start=00000, Device start=00000, Device end=0FFFF, I dont know if the addresses are set correctly, as this could be my problem?
Old Sep 23, 2007 | 02:24 AM
edfirebird's Avatar
Re: 27sf512 wont verify
Use the new software it fixes it.
Here U go
http://xtronics.com/memory/I-PP2Win2.41.exe
Old Oct 3, 2007 | 07:10 PM
edfirebird's Avatar
I also had the same problem with the new software. First you need to click erase device then program and it should be A-OK!
Eddie
Last thought, I first stacked the bin to fill the whole chip using tunerpro I filled all the solts with the same image . A bit redundant but it works just fine Ed
Old Oct 4, 2007 | 08:37 PM
kansan's Avatar
Car: 90 c1500
Engine: 383
I downloaded the software and tried that, still won't verify, actually now it won't even erase the eeprom. I think it might be my pp2, just not sure. I have the serial version of the autoprom but from what I gather it does not support the 27sf512(or at least wont erase it), although the usb version does. Thanks for the advise!
Old Oct 5, 2007 | 12:55 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Correct, the serial version of the AP does not support 27SF512.
Pinguiclia
Oct 12, 2015 04:47 PM
AmorgetRS
Sep 28, 2015 09:33 PM
camarohelp
Sep 22, 2015 03:19 PM
david068513
Sep 18, 2015 08:37 PM
manifoldsrme
Sep 17, 2015 11:40 PM
