Knock help please
Old Sep 23, 2007 | 09:10 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Knock help please
Hello, all
I am trying to stop a high rpm knock that i have been chasing for some time now, it is a 730 ecm. Here is my question tho, I had lowered the Knock Retard amount that is allowed down from the stock values all the way down to 4*. Now when i put my scanner on it the highest KR that it see's at WOT is 3.5*.
My question is "if" the value is lowered down to this point will the KS still show the actual Knock counts the engine is experiencing? or will it show only the 4* that i allowed it?
I am having a time getting it to stop , i really wanted to "hear" it or see some sign on the plugs. Neither is showing anything out of the ordinary at all. BTW i do have a short scan that if any one is interested in seeing i can sent it to them thanks.
Old Sep 23, 2007 | 06:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Knock help please
With spark knock, counts and retard are two different things. Usually counts are accumulative and then roll over. If knock counts arrive, they are noted, but not always acted upon.
Spark retard on the other hand, can be disabled. There is usually a lower temperature, MPH, and/or RPM threshold before the ECM will retard the timing. So there can be knock counts but no spark retard.
I have always gone by the plugs as to whether knock is truely present. To me, if they don't show knock, then the knock detection system is picking up false knock.
RBob.
Old Sep 24, 2007 | 07:13 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thanks rbob,
I too think that it is false KR, tho i do have a fairly noisy ValveTrain, RR etc
I just pulled the plugs today and i see no visible signs of deto, I am only getting the KR at WOT and only when the ecm is in PE. The entire time the car is driven normally there is Never a KR shown on the scanner even when under hard accell. ( not WOT ) Maybe i will return the KS to the stock setting just to be safe and just reduce the PE spark adder and see what happens.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
